Wich agp videocard?
First post, by Mentalbass
I've revived a Compaq Desktop pro 2000. Its an pentium 3 1ghz with 512mb ram. A Nvidia Riva Tnt2 m64 32mb ram in it. It runs on windows 2000.
I want to play Soldier of Fortune 2 on good quality but the graphics card is lacking in performance.
What is considered the best (agp) card for this system. Max i can put in?
Thanks for your advice 👍
Rise of the Triad
Reply 1 of 16, by flupke11
Anything around a Geforce 3 should do. What resolution do you plan on playing on?
Reply 2 of 16, by Mentalbass
flupke11 wrote on 2020-06-14, 19:12:
I think 🤔 800x600 or 1024x768 would do.
So i can put an geforce 3 in there? Wich memsize would do?
Rise of the Triad
Reply 3 of 16, by flupke11
64 MB is the standard around that period. Alternatives are the Ati 8500 or even 9000, and a cheaper alternative is the Geforce 4MX440. If you find a reasonably priced Geforce 4 4200 or up, that would even be better. So you're spoilt for choice.
Reply 4 of 16, by appiah4
GeForce 4 Ti4200 if you want the best possible performance for the most reasonable price.
That said, I don't think the CPU will cut it for Soldier of Fortune, which was a 2000 game and struggled on old hardware at launch.
Reply 5 of 16, by flupke11
A PIII 1.0 Ghz exceeds the recommended system requirements. Coupled with a ti4200 or similar, it should provide a fluid experience, especially at the TS' resolutions.
Reply 6 of 16, by appiah4
flupke11 wrote on 2020-06-15, 14:33:
SOF was a very CPU heavy game IIRC but there's one way to find out..
Reply 7 of 16, by maxtherabbit
1GHz coppermine was very good for y2k hardware
Reply 8 of 16, by Shagittarius
SOF 2 is a dog of a game, badly optimized CPU/GPU hog.
Reply 9 of 16, by Mentalbass
flupke11 wrote on 2020-06-15, 11:34:
Found an 4200 ti 👌!
Rise of the Triad
Reply 10 of 16, by Mentalbass
appiah4 wrote on 2020-06-15, 15:15:
Ill put in the 4200 and shove SOF2 up the deskpro's butt! Ill let you know......even try my luck with Farcry.
Thanks
Rise of the Triad
Reply 11 of 16, by flupke11
Enjoy!
Reply 12 of 16, by chrismeyer6
That TI 4200 will be a nice match for that system. What os are you running?
Reply 13 of 16, by Mentalbass
chrismeyer6 wrote on 2020-06-16, 11:44:
Im on win 2000. I thought about winxp but so far win 2000 runs good.
Rise of the Triad
Reply 15 of 16, by chrismeyer6
Good choice 2000 holds a special place place in my heart. It was just super stable and just worked
Reply 16 of 16, by Mentalbass
Mentalbass wrote on 2020-06-16, 08:10:
Thanks
It runs. But if you set all stuff on max at 800x600 it is playable but ingame with rain, first level its a little sluggish at points. Rest it runs good in with this card.
Sof is a heavy cpu intensive game .... farcry should be better?
Rise of the Triad
