AdLib vs Game Blaster
First post, by Mark_81
I'm trying different Emulated DosBox Sounds for The Secret Of Monkey Island
Adlib had Integrated Chip Yamaha YM3812...FM Synthesizers 8 bit mono sound
Here's an example...The sound is really Good...
https://youtu.be/B2aaSG3ICd0
Then I Tried Game Blaster..
Here's and example...The sound is Awful...Why? no Yamaha Chip (basically No Fm Synth)
https://www.youtube.com/watch?v=jWIBLgvtaN0
Reply 1 of 26, by mpe
Maybe it is just me but I love the CMS sound. Even if technically inferior to AdLib.
Blog|NexGen 586|S4
Reply 3 of 26, by mpe
Yes. Maybe not the map part. But stereo makes CMS sound nice.
It is not meant to be perfect. It is a pixelated VGA game after all.
Love the main tune (on any hw) or the LeChuck.
Check the real hw - https://www.youtube.com/watch?v=Fr-84mjV3CI.
Blog|NexGen 586|S4
Reply 4 of 26, by Mark_81
I'm capturing Audio with DosBox..
I get .WAV file at 1411 kbs 44. khz sample rate
What do you think about the quality of DosBox recording?
Reply 5 of 26, by Grzyb
Well, CMS is more limited than Adlib, therefore it's more difficult to compose a good soundtrack for CMS.
My favourite pieces of CMS music are those from Silpheed and Times of Lore, not Monkey Island.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 6 of 26, by Shagittarius
Square waves vs Sine waves. Most people prefer sine waves, so do I, it's no wonder CMS died, but at the same time I appreciate when CMS is used properly and sounds good like in the examples above or 'Don't go Alone' as another example.
Reply 7 of 26, by Deksor
One thing to consider is that creative didn't document some modes of the CMS chips which were available letting you change the envelope. Look for the Phillips SAA1099's datasheets for more infos.
I think this is a better demo of what the CMS card can do : https://www.youtube.com/watch?v=JgtKnwtbsac (and it's just "half a CMS" !)
Reply 8 of 26, by Mark_81
Deksor
Thank You, I appreciated
Reply 9 of 26, by root42
I love the SAA1099 sound. It’s squarewave and limited, but it’s really retro!
YouTube and Bonus
Reply 10 of 26, by Deksor
Here's more examples if you want to hear them 😀 https://www.youtube.com/watch?v=FpDKrdqYDbM
A project I had in mind for a while was to create the "definitive" tracker for Sound blaster 1.x and 2.0.
Basically it'd let you use, CMS, OPL2 and DSP simultaneously !
There's really nothing that seems to prevent you from doing that with these cards, so I wondered how it'd sound like !
Zone 66 (https://www.youtube.com/watch?v=JnbrosPkq_M) is the only game I know that uses both OPL and DSP for music, and it sounds awesome, so a trio of sound sources may even sound better 😁
(And also for game devs it could let you create music using the DSP and OPL2 and some CMS voices and then use the rest of CMS voices as easily programmable stereo sound FX channels)
Reply 11 of 26, by root42
DSP for drums makes sense. A good tracker for CMS would be cool.
A tandy tracker is on its way. Now one for the SAA1099...
YouTube and Bonus
Reply 12 of 26, by Mark_81
thank you all Guys
I'm an amateur and i'm new of this WORLD...
Is DosBox a good way to recording Audio?
At the moment,I'm capturing Audio with DosBox..
I heard about OBS/MUNT , but it's too complicated for me compared to Dosbox
here's a scan of the audio spectrometer
It's a scan of Monkey Island VGA floppy DOS Adlib main theme
Reply 13 of 26, by Deksor
No, DOSBox' emulated sound and especially the CMS sounds off.
I have by no means started such a project yet (I've just experimented a little before) and I've never written any sound related stuff as of yet so I may struggle doing that, but that's definitely on my "to do" list, unless someone else wants to do this before me x).
But to me this'd be more than a simple "CMS tracker", it'd be a "Sound Blaster" tracker (although you could still only write for CMS through this, but the idea is to make a better use of the sound blaster overall).
Reply 14 of 26, by Mark_81
Deksor
Dos Box is not Good for audio recording?
Reply 16 of 26, by matze79
root42 wrote on 2020-06-26, 18:09:
Yeah but Sam Coupe only has one SAA1099 and sounds much better then Stereo CMS 😉
Reply 17 of 26, by SodaSuccubus
I'm a simple person. Game blaster sometimes makes my ears bleed with its peircing tones. Adlib doesn't 😉
Jokes aside. It's an interesting peice of kit and sounds okay in some games (but horribly in others). I'd never take it over OPL though.
Reply 18 of 26, by Mark_81
Mark_81 wrote on 2020-06-26, 18:38:
Deksor
how to record Videogames music in good quality?
I'm not going to buying real retro-hardware and configuring a 486 IBM
What good options do I have ?what do you recommend?
