First post, by Cga.8086
Hello
i have this question in regards to computers from the post pentium3 era where ISA slot is not available anymore.
I have seen quite a few videos online showing how to build a retro pc with modern computer parts, so i wanted to ask :
what do you use for a computer that does not have ISA slot and you want to play all games from the 90s incuding all DOS games.
i always thought that in order to play properly DOS games you needed a SB16 isa card. This is because the sounds, tones are correct, i tried some time ago playing DOS games with an awe64 gold, and the sounds were not how i remembered when i played as a kid, therefore i didn´t like it.
when it comes to PCI i have heard good things about vortex2 , but does it sound exactly the same as a SB16 under DOS?
Other cards i have seen that are PCI are the yamaha XG pci cards, do those sound exactly the same on dos games as a SB16 ?
