First post, by flupke11
- Oldbie
As stated here, my 386 system took the house circuit break down. I've got the mainboard out of its cage and inspected it visually. There is some oxidation of the 4th ISA slot, and oxidation around the "RP" component halfway under that slot.
Am I wrong in thinking that the oxidised slot is the culprit? Any chances the board survived?
How would I best go about cleaning this area?
I will test the PSU and the other components later this weekend (time allowing).
