First post, by Nic-93
Hi all, am using some 3com isa card called 3c509b-c , do somebody know of an complete driver set with this particular card?
well, since then ive gotten the driver stuff working, but im now looking for a transfering program to windows 3.11 and hosting a folder, etc.
I had similar issues hosting files on modern systems and kept running into ntlm issues with older win3.1 clients. I ended up moving all my hosted folders to a FTP server and this seemed more consistent when using something like ws_ftp and mTCP on older clients.
Do you know one similar like mtcp for windows 3.11?
Nic-93 wrote on 2020-07-13, 01:08:Do you know one similar like mtcp for windows 3.11?
Just grab the telnet and ftp clients from Windows for Workgroups 3.11. They work in my 286 Win 3.1 set up just fine.\
You'll need Trumpet Winsock with winpkt loaded first.
Why bother with Trumpet? Try MS TCP32B instead. It comes with an FTP client. Of course this depends on you having a driver for it besides a packet driver.
jakethompson1 wrote on 2020-07-13, 03:53:Why bother with Trumpet? Try MS TCP32B instead. It comes with an FTP client. Of course this depends on you having a driver for it besides a packet driver.
In Windows 3.11? You must be joking. It doesn't support networking but Windows for Workgroups 3.11 does though and can use tcp32b. Trumpet Winsock works perfectly fine in Windows 3.11.
its wfw 3.11 im using for clearing up any confusion, since it already had network features part of it and aint that much different, so id need a general ftp program for it.
Tcp32b has a general FTP program
thats true, but aint that good, the program should act like a server to.
Looks like WS FTP is software of choice
FTP client/server for Win 3.1
ive been trying sorta to get that one working, but how do i make it do a server host?
Caluser2000 wrote on 2020-07-13, 06:46:In Windows 3.11? You must be joking. It doesn't support networking but Windows for Workgroups 3.11 does though and can use tcp32b. Trumpet Winsock works perfectly fine in Windows 3.11.
That's a good point, "Windows 3.11" I assume is WfW which sounds like is the case here, but may not be always.
I've never looked into whether the tcp/ip stack that comes with MSIE 3.x is dialup-only or can also do Ethernet.
Yeh WFW seemed to ship more often then not once 3.11 was out, enough that people simply dropped for workgroups.
But this was early days of networking and MS branding wasn't so much in your face so plenty of people installed Trumpet Winsock on 3.11 WFW as thats what the Windows 3x guide said you had to do to get on the internet.
As for WS FTP, no idea never used it myself but you could send a PM to the guys on the other post.
Personally I use windows networking. It's slow, a bit temperamental and have to copy files from my daily PC to a XP which can then copy to 3x so no not the most efficient but feels more authentic IMHO
has anyone ever gotten xitami on windows for workgroup's working on the said port 21?
i cant get it to run.
Caluser2000 wrote on 2020-07-13, 06:46:jakethompson1 wrote on 2020-07-13, 03:53:Why bother with Trumpet? Try MS TCP32B instead. It comes with an FTP client. Of course this depends on you having a driver for it besides a packet driver.
Which version of trumpet works on 286? I tried 3.0d and it crashed trying to run the installer
EDIT: found version 2.0B which works great. Now to search for 286 compatible software that can use it
