First post, by TheMobRules
I recently got a Tyan Tsunami 440BX board from 1998, and while it seems to be working perfectly, I noticed that unlike most other 440BX boards I've seen this one does not have a heatsink on the main BGA chip.
So my question is: does the 440BX really need some sort of extra cooling? The fact that my CPU cooler is on the way prevents me to check properly how hot it gets under normal use.
Now, I know that "a heatsink is always better than nothing", but in this case I would need one of those low profile heatsinks (so that it won't block the Slot 1 cooler) with some sort of adhesive, since there are no mounting holes near the chipset. I would prefer to avoid all that hassle right now unless it's really necessary as it is difficult for me to source that type of heatsink in this moment.
Keep in mind I don't plan to run the board overclocked or out of spec in any way.
Reply 1 of 7, by Horun
I have a Compaq 440BX board running a 500 and has no Northbridge heatsink, it does get warm but not hot. So I say if the board came without one you should be ok as long as you have good airflow thru the case.
Reply 2 of 7, by shamino
Lots of 440BX boards didn't come with a heatsink. I think most of the boards that heatsinked the 440BX were retail enthusiast boards. Whether that was to aid overclocking or just to look good, I don't know.
Many Intel boards that appeared in Dells and such had the chipset bare. But some of those were also heatsinked (I have at least one example on an Intel board), so there is some inconsistency there.
If your CPU cooler has a fan and deflects air onto the chip then that probably mitigates the heat a great deal. But if you don't think it's getting any ventilation then that might be a good reason to be concerned about it.
Given that you don't plan to overclock and that it's probably getting airflow, I think the heatsink would be totally optional.
In theory it could extend the life of the chipset, but these chips weren't failure prone so unless it's working long hours it probably doesn't matter.
Reply 3 of 7, by TheMobRules
Thanks guys. I have pretty good airflow in the case right now, so that isn't a concern. I'll keep using it with the bare chipset for now and later on when I have the chance I may buy a heatsink to put on it.
Reply 4 of 7, by PC Hoarder Patrol
I have quite a few BX boards and it seems more of a manufacturing (cost?) thing than anything else
With - Asus, Gigabyte, MSI, QDI
Without - Compaq, Dell, Intel
Reply 5 of 7, by maxtherabbit
My Tyan tiger 100 dually is in the no column
Reply 6 of 7, by chrismeyer6
I have a supermicro 440bx based dual slot 1 board and it has a heatsink on the northbridge
Reply 7 of 7, by amadeus777999
Enthusiast and business solutions may be the ones with a heatsink.
