First post, by deksar
I was looking for diagnostics diskette for IBM PS/1 Model 2168, on almost everywhere but failed to find.
The closest one I found was ps1diag4.zip (PS/1 Type 2133, 2155 Advanced Diagnostics Diskette), but did not work.
Anyone has it somehow? Please!
Many thanks.
Reply 1 of 3, by Horun
There are many IBM BBS archives and could not find it at any of those. Checked IBM.com thru archive org and also found nothing. If there was a link at Archived IBM.com that would have given me a name to search for but for some odd reason it is like IBM did not archive much for ps/1 2168 other than the manual.
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
Reply 3 of 3, by Intel486dx33
If you down load and extract the “Spring 1994 multimedia” image and extract then burn to a cdrom disk you can then install onto your computer using the “Xcopy /e/s *.* C:\” command.
https://ps1stuff.wordpress.com/download/downl … -for-type-2133/
If you just need basic diagnostics. Create a basic DOS boot disk to boot from then on another disk copy “MSD” to a floppy
Then run “MSD” on your computer.
‘Microsoft System Diagnostics’
https://www.allbootdisks.com/download/dos.html
DOS
https://winworldpc.com/product/ms-dos/622
