Reply 20 of 25, by 386SX
Jo22 wrote on 2020-08-04, 14:42:Glad to hear! ^^ If you like, you can also run CheckIt! , too. […]
386SX wrote on 2020-08-04, 14:00:Newer Scandisk, still no errors ! 😁
Glad to hear! ^^
If you like, you can also run CheckIt! , too.PS: You can also use bigger HDDs with a Dynamic Drive Overlay (DDO). Or XTIDE Universal BIOS.
But if it works the way it is, just leave it that way. 😀
Yeah I was already sad to think I'd have needed another 90's disk that nowdays are difficult to find imho in good condition and this was quite ok, low noise, not extremely fast but good thing is that also remains quite cool on the temperature side. I used a 8.4GB one with the overlay driver, it worked ok setting a single 504MB partition in dos, but they really got hot on the surface and the overlay driver is a great idea but for a Win9x installation more than a msdos one imho.
Anyway for now it's a great 386 config.. high end but have to study more into the HIMEM, EMM386 stuff to configure it I lost every memories on those things.
Question: I did all these tests without loading the GUEST app for the Iomega ZIP100 drive I had before when I had those errors. Is it possible ( I suppose not) that being connected to the same I/O controller but on the external parallel port, that drive would create some problems before that resulted in those writing/reading cluster errors? It's a strange idea but it's the only thing I've still not loaded after reinstalling everything.
