First post, by Asmodeusbell
Looking for a newer bios file for the SY-5EMA+ V1.1.
Google hasn't found any sites that have any bios files to download.
I found a site that listed bios revisions, the was newest it had listed, "01/06/2000-VP3-586B-8669-2A5LES2BC-00."
If any one knows if this mobo supports any of the K6-III+ or 3 mobile?
The manual for the v1.1 has the K6-3 400 and 450 listed in supported cpus, my guess its only the AFR and AHX models.
I have tried a K6-III+ Mobile 450ACZ, the mobo did not post with it. My feeling is, as this chip was release in 2000 that the newer bios is needed.
Current Bios
Award v4.51PG
08/03/1999-VP3-586B-8669-2A5LES2BC-00
Reply 1 of 12, by darry
I believe that these are the two most recent BIOSes for your board . Source : https://web.archive.org/web/20040327042549/ht … dl/bios/586new/
One of them is newer than the one that you found a reference to .
The BIOS from 2000 that you are referring to is actually for the 5EMA (without the +) . For some reason likely known only to someone at Soyo, the 2A5LES2BC board ID is shared between the Soyo SY-5EMA and Soyo SY-5EMA+ . The correct BIOS for the Soyo SY-5EMA+ is 5EMPVEA1.zip .
33.64 KiB
5EMPVEA1.zip
112.5 KiB
88 downloads
32.48 KiB
32.19 KiB
Reply 2 of 12, by Doornkaat
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
This site has the BIOS. It also confirms the board should work with K6-III(+) CPUs.
Other than that I recommend using web.archive.org to browse old images of the manufacturer's website if you're having problems finding BIOS or documentation for old hardware.👍
Cheers!😃
Reply 3 of 12, by Asmodeusbell
Thanks to Darry and Doornkaat. I was able to get a few of them downloaded.
@ Darry, From the two you posted, the second one i found was linked to the v1.0 of the mobo.
I had used web.archive on soyo old site. My luck was none of the download links would work.
Happy that this board worked as my FIC VA503+ quit posting. only beeps when no mem is installed.
Reply 4 of 12, by Repo Man11
darry wrote on 2020-08-09, 20:03:
I believe that these are the two most recent BIOSes for your board . Source : https://web.archive.org/web/20040327042549/ht … dl […]
5EMPVEA1.zip
Those of you who do so well searching the internet archive ought to post a page detailing how you do it.
Reply 5 of 12, by Repo Man11
Doornkaat wrote on 2020-08-09, 20:07:
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm This site has the BIOS. It also confirms the board should work with K6-III( […]
Cheers!😃
Unfortunately Jan's link goes to the now long defunct Soyo site.
Reply 6 of 12, by Doornkaat
Repo Man11 wrote on 2020-08-09, 20:40:
Cheers!😃
Dang, you're right. I'm on my phone so I didn't check.
Anyway, we can find the file name of that BIOS so just put it into your search engine of choice and often enough you'll find the file archived somewhere.👍
Reply 7 of 12, by Asmodeusbell
I've never had the best of luck with way back machine when it came to file downloads. I had look in oct and dec, those also went to the defunct soyo site.
Until now the only site i could find any sort of file name for the bios was what i had posted in the beginning.
In the picture was the only ref i could find using the the mobo name model.
    81.76 KiB
    201.93 KiB
Reply 8 of 12, by darry
The archive.org link that I posted in my first post in the thread has working downloads for BIOS files .
Here it is again, for your convenience : https://web.archive.org/web/20040327042549/ht … dl/bios/586new/
EDIT : 01/06/2000-VP3-586B-8669-2A5LES2BC-00 pretty much matches up with 5EMA1DA1.BIN . This BIOS seems to be for the SY-5EMA , not the SY-5EMA+ , as mentioned before .
Reply 9 of 12, by PC Hoarder Patrol
FYI
267.13 KiB
https://web.archive.org/web/20020613021241/ht … d486=&notebook=
Reply 10 of 12, by Asmodeusbell
Thanks for everyones' input. I wasn't having much luck in finding any thing for the bios for this board.
Happy to say, that the 5EMPVEA1 worked and the the K6-III+ Mobile 450ACZ is posting with no issues.
Made a back up copy of the original bios as well.
AMD k6-III+ 450
SY-5EMA+
256 MB PC100 CL2
Geforce 2 Ti
NEC USB 2.0
Sound Blaster 16 CT2290
Running Win 98se and Dos 6.22
Reply 11 of 12, by Nexxen
Direct dump from my m/b:
version 1ea1 (last for v 1.0 an 1.1).
Before the dl site is taken down. 7z file contains bin file + an empty txt.
    Soyo 5ema+ bios 1ea1.7z
    113.09 KiB
    67 downloads
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 12 of 12, by PcBytes
5EMPVEA1.zip
LuckyTech also did this somewhat. I just happened to have a copy of both the Rev C BIOS and the newer Rev D BIOS and both read 2A5LESHDC. The only differences I know on both are:
-sign on message (don't remember exactly but the Rev D had a longer sign on message than Rev C)
-EPA logo changes to the standard yellow Energy Star logo found on newer mobos (Rev C has the usual EPA Pollution Preventer text under it)
-Rev D supports drives over 64 GB, up to 128GB (or 137GB probably as that's the max LBA28 limit afaik)
