First post, by feipoa
- l33t++
Has anyone run into this issue before? I'm testing a Dell Precision Workstation 610 motherboard, which is a dual slot 2, 440GX motherboard. The motherboard has jumper settings officially up to 550 MHz, though two reserved jumpers support 600 and 650 MHz.
If I install a pair of 450/512K 2.0 V PII Xeons (Tanners), the system works fine. If I install a pair of 700/2M or 700/1M 2.8 V PIII Xeons (Cascades), the screen stays blank at power-on. Doesn't matter if I have the jumper set for 450 or 650 MHz. If I install a single 700/2M 2.8 V Cascade and a terminator card in the second slot, the system works just fine. Note that Tanner chips are based on the Katmai core and Cascades on the Coppermine core.
Has anyone run into this before and if so how did you circumvent this problem? Is 2.8 V drawing too much current for the onboard VRMs? According to https://en.wikipedia.org/wiki/List_of_Intel_P … microprocessors , the 700/2M chips dissipate less power than the 450/512K chips.
I'm also curious why the Cascade chips request a higher voltage from the VID table compared to the Tanners, didn't the coppermine chips run at lower voltage than the Katmai's?
Lastly, I was wondering if the 900/2M chips which sport 5V/12V would work on this board? Why did Intel make the cartridges demand such a high voltage? The VID table only goes up to 3.4 V. Would there be some logic on the motherboard which switches power over to the 5V or 12V plane?
Thanks!
