First post, by kirikl
Hello guys. I have Covox, Adlib and Tandy now on my parallel and all of them in 4 way switch. So much fun!
I want to know if I can switch it on the go. I obviously need to reboot system anyway to load TSR drivers.
But can I just switch or I need to shutdown the computer first and then switch to the next LPT sound?
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
Reply 1 of 2, by waterbeesje
With these I don't know... But I use laplink a lot, and I plug it in and decouple it on the fly, without rebooting. Ofc interlnk will need to reload in my case and in your case the TSR expects the old card... But I can't see any reason why just a warm reboot shouldn't work (even ctrl alt del)
Stuck at 10MHz...
Reply 2 of 2, by kirikl
Yeah! Warm reboot is fine (quemm is quick)
But is it ok for devices itself? I remember com and parallel ports were not intend to be hot swappable or something like that
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
