First post, by Deksor
- l33t
Hello everyone ! i have received SpectriaForce's damaged sb pro 2 (see here Re: Old hardware giveaway thread.)
So let's analyse the damages ...
The OPL3 seem to have 2 broken pins. Now they might be connected just by contact, but I'll replace this chip anyways.
Here you can see a capacitor that's totally disconnected
More damaged capacitors ...
I'm not sure if the card will work with broken caps, but we'll see.
And last but not least, here's a detail that could have been easy to miss (zoom in to see it) :
the HCF4053 chip has a notch in the top left corner. I don't know how deep that is, but that doesn't look good at all, I'll have to swap it too.
The PCB itself has some damage as well but I don't see any broken traces ... I'll compare it to my working sbpro 2 to make sure eveything's ok.
I can salvage a OPL3 from a clone card, but maybe it'd be better to not destroy working hardware to fix something broken ... Only I fear faked chips ^^
