This has been an interesting computer so far.
Installing XP on it has a weird quirk - I lose access to a PS2 keyboard during the install. If I connect a usb keyboard instead, that works fine.
I've also been playing around with older OSs on it. I can get Windows 3.1 to install, and sorta got 95 installing (safe mode worked, I need to tinker some more). This board wouldn't support those, I know, but I'm looking to build something that I can install DOS and Windows 1 on, and upgrade through all the home versions up to 10, and this board/processor can do 10 (already tested that successfully).
But, there's something off about the PS2 ports. The XP quirk is troublesome, as this hardware should support installing XP. But I find that with 3.1 and 95, I have no PS2 mouse. I haven't tried USB yet - which if that works gives me a working workaround. But what I've also noticed is that, consistently, when the OS boots ,moving the mouse results in the pointer moving a little bit, perhaps 1 pixel, and that's it. No further movement from that point. So ,it seems that the mouse works - it sees the mouse, it responds to it, but it immediately locks up.
Anyways, not sure if anyone else out there has experience with these boards, or can offer insight to working with PS2 problems on this board. It just happened to be the cheapest ebay board at the moment that will take a P4 that can do Win10. I probably should have held out for an ASUS that would do it, I'm more familiar with those. But....this has been an interesting board so far.
