First post, by mt777
I got this mobo without CPU/Dallas/Bios and almost all jumpers were missing.
I programmed bios P06Y034Q.PRD and put P90 cpu.
Unfortunately still not boot and any post code.
CPU is not warm so firstly would desolder SMP50N06 and check via multimeter?
Photos in google drive (due to size):
https://drive.google.com/drive/folders/1F7dl0 … LXw?usp=sharing
Reply 1 of 5, by PD2JK
Is that FET getting warm at all?
Here a simple guide:
https://www.utm.edu/staff/leeb/mostest.htm
Reply 2 of 5, by Deksor
I have a manual for this board and so I scanned it and created a entry here : http://www.win3x.org/uh19/motherboard/show/6225
I'll upload your image 😁
Reply 3 of 5, by mt777
I checked via this: http://electronicsbeliever.com/how-to-know-if … t-is-defective/
and always got 0 on diode test. So probably is defective. Now worse job is finding replacement
// RFP50N06 is reasonable so will try with it
Reply 4 of 5, by mt777
still on investigation.
Can someone take a pic of JP22 (below cpu and next to RTC) ? It is a resistor probably but don't know which value..
https://www.x86.fr/cpus/Nx586-02.jpg
is there a resistor between 1 & 2 pin which what value?
I put 1.5kOhm resistor but didn't help 😀
Reply 5 of 5, by H3nrik V!
Isn't PCI version compatible with P/F processors only? It is it only the other way around, that vlb boards are not?
