First post, by dulu
Current specs:
- PIII-S 1400 - modded; connected AM34 with AK36, AK26 with AK4, ; isolated AN3, AJ3, AK4. Also connected AM36 with AL37 (vid1 with vid2) for greater voltage - i checked this connection by the multimeter on the back of the motherboard, so i`m sure that cpu has higher voltage.
- Asus CUV4X-CME/MEDION2001
- 2x256mb SDRAM - infineon CL2 and twinmos CL3. Both works stable with 2-2-2-6
- MSI/MEDION TI4200
- Audigy 2 ZS
- WD 80GB/2MB
I cannot get greater fsb than 142. I think i tried everything. PLL chip is ICS 9248-98, same as Asus CUV4x-M, but on CME board i have to use CPUFSB app for editing fsb. This maximum stable fsb (140, PCI 35MHZ) is a wall for all of variants that i have checked.
Variants:
- two different disk`s
- two diffrenet modded cpus - before PIII-S 1266
- two different GPUS - before MX440
- reducing ram timings for 3-3-3-7
- trying with only one module of ram
- increasing ram access latency (i don`t know what is it exactly) to 2 ns
- changing ram multipler - so when CPU has fsb 133, ram has 100
- removing soundblaster and disabling onboard soundcard
- disabling one of the IDE connector
- disabling com and lpt ports
- using bigger cooler for socket 478 with 60mm fan
Also, i noticed that with fsb-142, superpi-1M can be passed, but usb mouse and keyboard freezes. What else can i try? I wonder if original CUV4X-CME has more options in BIOS but didn`t found any info, and i don`t have any floppy disk.
    97.44 KiB
Reply 1 of 8, by The Serpent Rider
That's more or less usual VIA 694X overclocking headroom. My ASUS P3V4X has FSB wall at 148 Mhz. The are few boards which will perform better, but CUV4X-M is most likely not one of them.
Reply 3 of 8, by The Serpent Rider
That's typical Nvidia driver behaviour with early AGP 4x VIA chipsets. You can force AGP 4x and other features via RivaTuner.
Reply 4 of 8, by Horun
dulu wrote on 2020-10-01, 13:18:
Maybe someone know hows to fix AGP bandwitch? CPU-Z shows 2x mode on both ti4200 and mx440, while mainboard supports 4x, and that value has been set in BIOS.
Are you running XP ? Or Win9x.Vista ?
The Serpent Rider wrote on 2020-10-08, 23:02:
Yep been there and VIA GART had issues....
Reply 6 of 8, by Hanamichi
Keep it on 3 3 3 7 for memory.
Try only one stick of memory.
Try a PCI graphics card although it's not a high fsb so unlikely to be too high clock rate for AGP.
Heat won't be the issue.
Try disabling usb, might have to tab a lot.
Best of luck.
166Mhz is not hard on a 820e (b) chipset, VIA 133a may not be able to do it sadly.
Edit: HWBOT has some quite high entries for FSB on this chipset and others reporting 150Mhz.
Definately worth trying a PCI graphics cards or at least uninstalling all video drivers and the VIA ones so you are on the basic display adapter driver. Ruling them out as an issue.
