First post, by jheronimus
- Oldbie
Hi, all
Got my hands on a Tandy machine, trying to figure out the best way to set up the software and video capture.
1) Originally Tandy came with a custom DOS 3.2. Is there any official procedure that would allow me to upgrade to 3.3 but retain Tandy-specific features (namely, mode.com enhancements, etc)?
2) Am I correct in my understanding that Tandy did not provide any installation tool for DOS 3.2? The correct way is to format the disk with /s flag, copy all the files from the installation floppy and manually create autoexec.bat and config.sys? I've been following this procedure.
3) I'm using EasyCap to capture composite output from the machine.
Running mode tv works great to make the command line output much more readable, here is an example.
Unfortunately, running any graphical app like Volkov Commander or a game resets the video mode. Is there any way to keep the mode permanent?
Here is how Street Rod looks in Tandy mode. I did not run mode tv in this video, but it would reset either way.
