First post, by lalakobe
Hello guys, I need some advice from you/
So today I got old IBM CGA video card by mail and wanted to check it in my 8086 machine.
Upon power up, one of the capacitors blew up!
323.46 KiB
Back of the board:
452.49 KiB
This is one of the three-legged tantalum capacitors that were popular back in the day, right?
Original was 16V 10mf.
Can I just replace it with modern two-legged capacitor 25v 10mf I have?
145.69 KiB
Reply 1 of 2, by Horun
Yes but you need to check which is ground, most 3 leg Tants the outside legs were ground and the middle was positive (not sure why they did 3 legs since the grounds were typically internally shorted except to use as a feed thru). Use a Digital ohmmeter and check that the outside leg holes are truly ground, should be 1 ohm or less. Then you need to wire the two grounds together and attach the new cap.
Reply 2 of 2, by kdr
I'd recommend using a 10uF 25V tantalum cap as the replacement. It'll keep the card looking more authentic and will be better suited for smoothing out high-frequency switching noise than a generic electrolytic. It's not difficult to find a suitable (2-leg) tantalum.
