Pentium 90 @ 120Mhz
First post, by Shagittarius
Hey guys, I just got a 120Mhz Pentium (Socket 5) for my Triton motherboard to replace my 90Mhz chip. When I slot in the new chip the board never gives the all is well beep and I get no video. Anyways it seems like something is wrong with the new chip though I cant see anything physically wrong with it.
Anyways I decided to see if possibly the motherboard couldnt handle it even though it is supposed to so I overclocked my 90mhz chip to 120, and it works fine. So I'm assuming something is wrong with the new chip.
Now on to my real question, since the board runs fine at 120Mhz with the P90 chip (which has an active HSF) do I even need to bother with an official 120Mhz chip? Is there anything wrong with running my P90 at 120Mhz long term?
Reply 1 of 21, by debs3759
If you can keep the CPU cool enough, it shouldn't be a big problem, but overclocking by that much long term can cause the chip to degrade faster.
Reply 2 of 21, by Shagittarius
I believe its not entirely stable after a little warm up period. This might not even be a question, I guess I'll have to find a working 120.
Reply 3 of 21, by mpe
Chances are that the real P120, that has been manufactured using more efficient process will run cooler and be more stable that the overclocked P90 part.
Those CPUs cost peanuts so I'd personally use the real thing just for good feeling.
Blog|NexGen 586|S4
Reply 4 of 21, by TheMobRules
If the CPU does not get overly hot and is running at stock voltage then it should be fine, Pentiums are known to be good overclockers, though you may want to perform additional stability tests.
Regarding the 120MHz CPU, maybe it's one of those that requires additional voltage to run properly? What are the 3 letters on the back of the chip? It can be something like SSS, VMU or other combinations. The first of those 3 letters indicates whether you should use STD (S) or VRE (V) voltage, and there should be jumpers on the mobo for setting that in addition to the bus frequency and multiplier.
Reply 5 of 21, by Shagittarius
It is VMU and the manual says:
Advanced/ZP Technical Product Summary • Page 16PROCESSOR VOLTAGE REGULATION - SWITCH 2Sets the output of the on-board voltage regulator. The switch settings are OFF = VR, and ON = VRE. The VR voltagespecification requires a voltage range of 3.3-3.465 Volts DC, while the VRE specification requires a voltage range of 3.45-3.6V. Pentium processors currently available that do not require the VRE voltage specification should use the VR setting.When upgrading your CPU be sure to consult the documentation for the processor voltage requirements before setting thisswitch, as an incorrect setting may damage the processor. The default position is with the switch set for VR (off).
So I need to check and see if switch 2 is set to on as you specify.
Reply 6 of 21, by Shagittarius
Got the same results as the other voltage setting, maybe I damaged the chip by trying it with the wrong setting to begin with.
I'll look for another 120 chip.
Sorry for the link to ebay, but what would the pictured chip be set to voltage wise:
https://www.ebay.com/itm/Intel-Pentium-A80502 … TgAAOSwSYdbxm59
Edit I ended up picking up a couple chips that were SSS, so those should work without changing the voltage setting from my p90.
Reply 7 of 21, by quicknick
It's not possible to damage a 3.3-3.465V chip at 3.45-3.6V, you should ask for a refund as you got a defective CPU.
Your P90 could probably handle 100MHz very well, and the performance would't be too far off the P120 due to the higher FSB.
Reply 8 of 21, by Shagittarius
Do you think I could run a Pentium 150 at 132Mhz by setting the FSB to 66Mhz and the multiplier to 2 even though the motherboard doesn't specifically specify that CPU? Would I at least be able to set the 150 CPU to run at 120 since the motherboard does support that?
Here is my motherboards manual:
http://pdfstream.manualsonline.com/1/1108b1a2 … 8973a837ed0.pdf
Im wondering if setting the FSB to 66 will throw off the ISA bus speed too much...I guess I'd have to experiment, I just dont want to kill the board.
Reply 9 of 21, by TheMobRules
Maybe something like this could work?
https://www.ebay.com/itm/270818967936
Don't take my word for it, perhaps someone else can confirm.
EDIT: seems like you edited your post, but I'll leave the link there in case it's useful.
Reply 10 of 21, by Shagittarius
TheMobRules wrote on 2020-12-01, 05:28:
Thanks that does look like the proper cable! Sorry for the edit, I've been shopping in real time, didn't mean to confuse.
Reply 11 of 21, by AlessandroB
Get a Pentium 166 PGA. like this:
https://www.cpu-world.com/sspec/SY/SY037.html
I have one and I can set it to any existing pentium classic frequency, both multiplier and bus without the slightest problem. Probably its production process is the last of the pentium1 series given the typical package of the pentiumMMX and holds 200Mhz perfectly fresh. I use it to see how the software works at various frequencies from 75 to 200mhz
Reply 12 of 21, by H3nrik V!
Pentium 120 came in two variants, the "classic" P54C and the die-shrunk P54CQS. It may be your board doesn't support the die-shrunk versions, since it also doesn't mention 133, which is P54CS.
According to my notes, the P54C versions of Pentium 120 are s-specs and Q-specs: Q0707, Q0708, Q0711, Q0372, SK086, SX994, Q0785, SY033.
Where as the P54CQS are s-specs and Q-specs: Q0776, SK110, SY062
The following s-specs and Q-specs, I am not sure whether are P54C or P54CQS. Q031, SK084, SY008
What s-spec or q-spec is your P120?
Reply 13 of 21, by dionb
Shagittarius wrote on 2020-12-01, 05:07:
With this sort of stuff, always consider that manuals are written at time of release and rarely if ever updated. Despite some internal changes (die shrink, reorganized components), the P54C (Pentium 75-100), P54CQS (Pentium 120) and P54CS (Pentium 133-200) present exactly the same interface to the outside world. Your board may lack the (BF1) jumper required to set 2.5x/3x multiplier, but if you put any Pentium CPU in this board jumpered for 120MHz, it will run it at 120MHz, and any Pentium CPU rated 120MHz or higher will be able to handle that if not dead.
Eh? Take a look at page 16 of the manual. Generally you'll want to run ISA at 8.33MHz. You can only hit that with 50 or 66MHz FSB, not with 60MHz. With SW1 on, you'll always stay at or below that value. However as the manual states, it's not the board that will have trouble with higher speeds, it's older ISA cards. In any event, you're not going to kill the board with officially supported settings (if the board can't handle those it's already borked).
I'd recommend reading up on the kinds of things that can kill old hardware, as you seem to be very cautious towards the wrong things. I'd recommend a focus on proper ESD practice, making sure your PSU is good and testing new components in a different (more expendable) system, as those are the big reasons why (old) hardware dies, not using supported settings of a very conservative board from a very conservative vendor.
Reply 14 of 21, by mpe
Surprised there even was a P54C version of the P120. I remember when the P120 announced the 0.35 μm process that made it possible was a major part of the press coverage. Despite using the same die area as P54C (and thus the P54CQS). I'd assume they later switched to P54CS and not the other way around.
Blog|NexGen 586|S4
Reply 15 of 21, by Shagittarius
This is what I figured just thought I'd ask before I did so...
Thanks I was a little confused since that graph goes by processor speed and not FSB speed, I was unsure how an FSB speed of 66 would have effected that.
This brings up another question though, If I've only got a Sound Blaster Pro 2.0, a SCSI controller card, and a Roland MPU-401 interface in the ISA slots what would be the benefit of running the ISA bus at a higher speed? Maybe faster throughput for the SCSI HDs? It seems likely to cause problems for the Soundblaster, and even if not, what good would that do?
I'm not really that afraid, I dont have the desire to get any more hardware to test with which is why I just wanted to ask if I might run into any board destroying problems...thanks for the advice.
Reply 16 of 21, by Shagittarius
H3nrik V! wrote on 2020-12-01, 08:13:
My 120 that seems to be dead is the SX994
Reply 17 of 21, by drosse1meyer
Shagittarius wrote on 2020-11-30, 22:51:
Got the same results as the other voltage setting, maybe I damaged the chip by trying it with the wrong setting to begin with. […]
I think VRE was only used on very few P5 CPUs but I can't find a definitive list. *most* socket 7 pentium (non-mmx) should use 3.3 (aka STD) core voltage
As a general rule, running a CPU (or anything I guess) at a higher than rated voltage means more heat which means shorter potential lifespan.
Reply 18 of 21, by Shagittarius
Success! Thanks everyone who contributed here, I got a P-150 running at 133 on this board today and, after about an hour of gaming / benchmarking, it seems to be stable.
Reply 19 of 21, by H3nrik V!
So the conclusion must be that the 120 was defective?
