First post, by kirikl
- Member
Hello guys.
I'm trying to get this card working in Windows 98. It is working without driver, but obviously it has to be installed properly.
It's ATA133 PCI Raid card. Works in DOS fine.
When I tried it with Windows 98 it hangs at boot, so no Windows screen. Just stops before. When I delete controller from System in Safe Mode it boots again, but then it tries to install same stuff.... I tried different drivers, from SYBa and Silicon
same
It's PIII BX chipset motherboard. Wondering if I can get advantage of 133 IDE or maybe 33 will be ok for that system 😀
Anyway. Appreciate your advise if you have experience with that
Thanks!
Here is the picture
http://it.us.syba.com/product/43/02/01/2/sd-ata133R_1_02.jpg
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
