First post, by Bertert
I'm wondering if industry mainboards are a good base for compatibility with many different cards and relatively low power consumptiuon. (provided you get it for a reasonable price.)
Are there possible problems?
With using a pci-isa bridge for example.
With ressource conflicts ? From the looks of the manual it's highly configurable.
The board I'm interested in is a mb892 : https://www.manualslib.com/manual/725032/Ibas … logy-Mb892.html
Socket 479 with Pentium M (1,8GHz 400MHz FSB),
has two DDR Slots,
2 IDE header
FDD header
AGP4x,
four PCI,
two ISA Slots.
also two Sata ports with a SiI3512 controller
6 USB 2.0 ports
32 pin Disk on Chip socket
Type II CF socket 1 port using IDE2 Slave channel (seems to be configurable)
Chipset Intel 855GME / 852GM Chipset:
PCI to ISA bridge Winbond 83628, 83629
Audio ICH4 Built-in Sound controller
Thanks
