I did a first look onto the connections and did not find any obvious broken thing. But I do not have any experience with this, so didn't know where to look.
My CF card arrived (2GB AGFAPHOTO 120x) and I cannot get it to work.
Adapter is a DELOCK CF to IDE adapter.
If I set it to master, the board won't boot, displaying either garbage on the screen, or dying at "40".
If I set it so slave, it will boot, but I dont know the correct settings (cylinders, heads and sectors) so cannot access it.
When I access the CF with a card reader on my PC, everything works.
I copied a working DOS image to the CF with dd and made the disk bootable with "CardTricks".
I tried the adapter in another PC (Asus P5Q, Intel Core2Quad, *maybe* 2009?)
It's "Marvell"(? cant remember xD) IDE controller finds the card as PATA CF-Card 2GB, the jumper setting seems to be irrelevant.
It only said at first, that the disk was invalid.
When I booted from the DOS floppy, it could access the disk, but would only show wrong data. It did read something from the CF, but that seemed like random bytes from it.
"dir" showed different information every time, and eventually only "File not found", the disk label was every time random ascii.
After many tries with "sys c:" and "fdisk /mbr" I managed to access the card correctly! Every information was there, and after I booted from the floppy and executed autoexec.bat, it was just like the system on the card. But when I tried to boot directly from the card (which worked!), it would not find anything on the card, dos booted, said file not found for autoexec, and I get a basic shell with no functionality than dir and ver, dir showing some of the files and folders correctly, and the second "dir" ends with "file not found".
scandisk with surface scan started from the floppy doesn't find anything.
As I intended to find out the configuration I tried many tools which claim to find the settings. (ideinfo.exe, idediag.exe and idthatide.exe) On the P5Q, none of them worked. IDETHATIDE failed with a "Ready error", the disk never got ready, idediag doesn't find anything, ideinfo.exe said, the bios reportet 1 drive, hardware scan didnt find anything. Could be the "too new" PC.
So I booted the floppy on my 386 with the cf adapter connected as slave, bios was set to empty (when I set values like 4095 cylinders, 16 heads and 63 sectors, it dies with HDD controller failure).
One time, the board was ok long enough to execute ideinfo.exe, and the screen instantly turned to garbage (will attach a foto of it, from the vga bios "garbage version"), the only line I could read was "sectors: 63", so that did work to some point! After it finished, I got a garbage version of the command prompt and the board froze 🙁
Is the adapter broken? The reviews on amazon stated, that it would not work on slave setting, scrambling data in this mode, but master would work 😒
https://www.amazon.de/gp/product/B001C852NO/r … 0?ie=UTF8&psc=1
As I wanted to have only one IDE device on the board and it was the only one which was cheap and available, I wanted to try...
