First post, by W.x.
Hello, I want to know, where is approximately DTK socket 7 motherboard in quality on scale:
Where on TOP are Asus, FIC, Shuttle
In middle Gigabyte, Soyo, Soltek , Biostar, MSI , QDI, etc.
On bottom
Amptron, ECS, Matsonic
PC Chips
These are DTK motherboards
http://www.motherboard.cz/dtk.htm
Are they decent? More like 5/10? Or more like 3/10?
Reply 1 of 16, by mpe
Not sure if it could be generalised like that.
I remember when I was shopping for a socket 5 motherboard back in 1995 the Soyo was definitely a premium motherboard brand compared to Shuttle I ended up getting.
It is true that PCChips and like are usually budget offerings (some exceptions). For other brands it usually depends on the actual model
Blog|NexGen 586|S4
Reply 2 of 16, by The Serpent Rider
Biostar in middle... ha ha.
Reply 4 of 16, by W.x.
The Serpent Rider wrote on 2021-01-08, 10:59:
Hmm, I have feeling, you didn't get it.
They are between PCChips, Matsonic and TOP ones. I didnt meant it to differate those in between them, of course, those middle ones have also different levels.
But definetly, I don't feel, Biostar is on PCChips level.
Reply 5 of 16, by The Serpent Rider
Regardless of the brand, you would want to avoid any motherboard with RTC battery, if you lack soldering skills.
Reply 6 of 16, by W.x.
The Serpent Rider wrote on 2021-01-08, 11:08:
Thank for advice. I almost missed it, it has not coin battery. You're right, I won't take it then.
Reply 7 of 16, by rmay635703
OEM Proprietary DTK were rock solid through 1991, (albeit sometimes rather slow lacking cache)
Never saw a 486 DTK let alone socket 7 so can’t comment, I do know that I had issues moving a 386sx25 DTK Board into another case as nothing lined up but again can’t comment on a socket 7
Reply 8 of 16, by dionb
DTK was one of the bigger brands in the really early days (1980s), but quite rare by Pentium era. The old stuff was pretty robust, but can't say I've ever handled 1996-era things of theirs. Brand alone can be a very bad advisor - brand quality varies over time, and even the best brands sometimes make steaming piles of crap. Also consider that "quality" has many aspects. Are we talking build quality? Reliability? Compatibility?
I'd suggest looking up info on the specific board, and failing that (wouldn't expect to find much in this case), just 'reading' the layout. To me this one looks like a pretty generic i430VX babyAT board. 256kB of PLB cache with COAST slot for more. What looks like PS/2 header for a mouse. Potatocam pics make it tricky to be sure, but at least the multiplier & FSB settings are documented on the silkscreen.
On the downside, an old-style inefficient/hot linear voltage regulator for 2.8V, and that Dallas RTC.
As for the latter- I'd not consider it a show-stopper as you can buy them new (Dallas is called Maxim these days and still makes the DS12887) or you can get homebrew replacements (basically a little PCB with SMD DS12885 and a coin battery) or you can mod the current one with a battery. What does matter (at least in terms of work involved) is whether the RTC is socketed or soldered. Taking a good look at the last pic, I clearly see a horizontal line on the side of the RTC - it's socketed. So yes, I'd prefer a CR-2032-based board, but failing that, this one is perfectly serviceable and the RTC can be replaced without tools or effort. I pay around EUR 11 for new DS12887 modules. Look up what they cost locally from a reputable electronics supplier (not eBay, you then get old stuff with batteries already dead) and factor that in to the cost of the board.
Reply 9 of 16, by The Serpent Rider
Looks soldered to me. Then again, for 50 bucks, it's probably better to look for some ATX board.
Reply 10 of 16, by dionb
The Serpent Rider wrote on 2021-01-08, 12:58:
Applying best CSI-skills:
55.63 KiB
Reply 11 of 16, by The Serpent Rider
Yeah, I did that too. Still not convinced. Here's a better picture of the board: https://www.ebay.de/itm/174563941088
Reply 13 of 16, by Deksor
While making UH19 we noticed that some brands are actually the same. DTK is also Gemlight for example.
And the "bottom" range of boards can be resumed to one brand : PCChips.
Now ECS is a different story. As @dionb mentioned, quality changes over time. ECS made pretty good 486 boards in my opinion. Plus most of them didn't have any barrel batteries. Then in the late 90's they got closer and closer to PCChips until they bought them. So they pretty much became PCChips.
As for PCChips, in my opinion build quality have always been between "meh" to terrible and they've always done shady things like hiding the chipset's brand, soldering the bios, having 10 brands for one board, etc.
However despite all this many of their board still work to this day (might be the survival bias tho ?). Maybe that's also related to the fact they dropped the varta batteries quite early which makes them much more convenient these days. Moreover they often put features that other brands didn't put in their boards and they also managed to make their boards quite fast.
It's almost too bad that they were trying to scam people. If they didn't do that but kept their qualities they could have been a pretty good and respected business nowadays.
This is why some people consider the PCChips m919 as one of the "Ultimate 486 board" I think.
Reply 14 of 16, by The Serpent Rider
Yeah, it boils down to specific boards. ASUS also had quite meh boards in that time period. I was surprised to discover that Zida Tomato made decent PPro motherboard.
Reply 15 of 16, by W.x.
Deksor wrote on 2021-01-08, 15:45:
Well, in this Toms reviews of VIA socket 370 boards, from mid-2000, ECS ended "quite well". (like, not bad, I mean. For the price)
https://cdn.mos.cms.futurecdn.net/YisY5MyXstpzCR6RPxaeuH.gif
Who would expect for example, Abit would end up about same as QDI? Of course, it's good always to test direct board (and even BIOS version, and revision)
It's Comprehensive VIA motherboard roundup June 2000, ECS description is here in slightly older review , although he didnt recommended the board. Of course... but I think, price was quite good. Still , not so bad, when you expect them on bottom, like PC Chips. Definetely didnt ended on last place thought.
https://www.tomshardware.com/reviews/12-socke … ards,196-7.html
So I would say, overall, they've made slightly better boards, than PC Chips. And from time to time, they suprises (possitively - for the price, that was low)
The purpouse of the hierarchy was, when you don't know about board, and you need to take it fast, you are risking, but overall, when you take Abit or Asus, you have less chance, when you take random board, that it will be bad. When you take ECS, you have much higher chance, that it will be eighter bad, or below average. Also with worse capacitors, thinner PCB, and durability. It was not like, no board from ECS can be good, and all boards from Asus will be always on top. But , when you take statistic when you blindly take board, highest chance will be on Asus and Abit, it will be good take. On PC Chips, you almost always will have terrible, or below -average board. That was purpuse of hierarchy. I wanted to know about DTK, where it "overall" is.
Reply 16 of 16, by dionb
W.x. wrote on 2021-01-16, 12:16:
Tbh, Asus boards certainly won't always be on top. Yes, if you completely randomly buy a board based on brand only, you have better chances with Asus than with ECS, but that won't help you one little bit with say the P3C-D (I literally needed to acquire 10 of those boards from 2002-2020 until I found one that actually worked last spring), P4P800 (great boards, but the VRMs had the alarming tendency to utterly fail without warning) or the A7N8X-range (fast and stable - but memory compatibility was horrendous, DIMMs that had no problems on Gigabyte or Abit boards with same chipset refused to boot or gave massive errors).
'Hierarchy' stuff is just a crutch for insufficient information. A far better idea is to solve the information problem and to research the specific board. If it's great, it doesn't matter if brand reputation in general is awful, if it's shite, no amount of good stories about other boards from the brand will help.
