First post, by Frrayground
Hey guys, I'm hoping someone can give me some insight on what the problem is with this build!
I'm working on building a Windows XP retro gaming PC and I'm having issues with getting it to POST with a certain CPU and RAM combo. Here are the parts I'm using:
Intel D975XBX2KR mobo
Intel E8600 CPU
Zalman Cnps9700 cooler
DDR2 6400 800mhz RAM
Asus GTX 285
Corsair 750w Bronze PSU
This all used to work great in an older case until I tried to upgrade the RAM from 2x2 GB sticks to 4x1 GB sticks. Now none of them will POST.
When I turn it on, the fans are quiet at first and then everything goes to 100% fan speed and there's no video output or anything.
If I put in a E6600 CPU it works just fine! Just not with the E8600. But it all used to work together so I'm really confused.
I think it has something to do with the RAM and maybe RAM frequency? If I use the old RAM sticks and manually set the frequency to 667mhz instead of 800, it will POST with the E8600. I have to put in the E6600 to make the changes and then swap the CPU. So with the 667mz change, it does work... But the fans are all at 100% speed and the BIOS says the processor is only running at .40 ghz. And doing the same frequency change with the new RAM sticks doesn't work with the E8600...
I ordered a second E8600 because I thought the CPU was just bad, but the second one behaves the same way.
Any ideas or insight would be greatly appreciated! I have a feeling I just need to get the RAM frequency and timings right to make things all work, but the processor showing a .40 ghz is what makes me think maybe it's something bigger?
Thanks so much for any help guys!
