First post, by Kotu Koylu
Hi vogoners. I have a aptiva 2144-910 model machine.
Board id is Type F-1
Machine default config cpu is intel dx2 66
1.My goal is upgrade cpu to cx5x86 /am5x86
Bios is up to date(1998)
But cpus ge toooo hot.does this board has a vrm? Or am i run this cpus at 5v?
2.The other question can i use 512k-50ns memory module for upgrade video memory(original config is 512k-70ns)
As here stated dx2 and dx4 have same jumper config?
https://stason.org/TULARC/pc/motherboards/I/I … -APTIVA-21.html
Reply 1 of 6, by Nitroraptor53
DX4 requires 3v, and DX2 is 5v, so they SHOULD have different jumpers. Then again, the closest thing I have to an Aptiva the the IBM PS/1 Tower Model, so no idea, sorry
"Oh I'm a good old rebel, now, that's just what I am."
MIcro ATX 486 Project
Twitter
Reply 2 of 6, by Kotu Koylu
Problem is there has no voltage regulator in my mainboard.
Reply 3 of 6, by Nitroraptor53
You'll need an external Voltage Regulator or an Overdrive, I think there's a voltage regulator on Amazon, one sec...
Twitter
Reply 5 of 6, by caiot5
Sorry to reply to such an old thread but I came to report that I have an IBM Aptiva with TYPE F-1 board using a Cx5x86 100MHz and it works just fine.
The settings looks the same as DX4 CPU, and you can use the following guide as a reference:
http://ps-2.kev009.com/pcpartnerinfo/ctstips/ea3a.htm
TYPE F-1 boards are fully compatible with DX4 100MHz, however TYPE C-1 boards are not, in the case of TYPE C-1 you should use an Intel Overdrive DX4 "ODP " CPU.
I hope that helps at least some of you, I will leave it here for further reference.
Regards,
Caio T5 from Byte5
Reply 6 of 6, by mael_b
I try to upgrade to a dx4 and I too have some issues... I just open the JP10 jumper (to set to 100MHz) as I've seen in the manual but... It doesn't work (I have some beeps, 2 longs and 4 shorts...)
If you have tips, feel free to share
TY 😀
