First post, by mwdmeyer
Hi Guys,
Back in the day (late 2005) I purchased a cheap Radeon X800 Pro for use in my Athlon 64 AGP machine. Specifically for HL2. Great card (but very noisy!).
Anyway I recently got it out again to test and found that the specs don't match up 100% with anything that is listed as an X800 PRO.
GPUZ says it is an R430 card which doesn't match up to the PRO name. It seems like a mix of a plain X800 and a X800 PRO.
Does anyone have any ideas or could GPUZ be wrong?
Reply 1 of 8, by Error 0x7CF
Interesting.
Differences from X800:
X800 Pro memory clock
Apparently claimed to be an X800 Pro
Differences from X800 Pro:
110nm R430 GPU like the X800 and X800XL
X800 GPU clock speed (400 vs 475MHz)
You could probably just "over"clock the GPU to 475MHz and call it a day if you wanted. It seems unlikely we'd get to the bottom of why your card is like this.
(My guess: Palit got some lower-binned X800 GPUs to sell as x800 Pro cards and figured nobody would notice or care. It's hardly a big difference. That or they ran out of R420 dies and swapped in R430s for some cards and switched to a lower GPU clock.)
Old precedes antique.
Reply 2 of 8, by mwdmeyer
Thanks I think you're right. I did a bit of looking into the card and old emails. It is branded as an XpertVision and it seems it is simply a X800 non-pro with PRO speed memory. The photos of similar cards online all look like normal X800s.
I'm not concerned that it doesn't match 100% with the PRO. It ran great back in the day.
I recently picked up an X850 XT and it isn't that much faster (although I was testing on a P4 2.8 so CPU is probably a bottleneck).
Reply 3 of 8, by The Serpent Rider
You can't. R430 usually can be overclocked only to 450.
Reply 6 of 8, by havli
The Serpent Rider wrote on 2021-02-07, 07:58:
Depends on luck, I managed to run my R430 at 540 MHz, no mods or anything. https://hwbot.org/submission/2566166_havli_3d … ddr1_1514_marks
Btw - it is werid to see R430 on AGP card. There must be the Rialto bridge... and therefore more complex PCB. As far as I know R430 is native pci-e GPU.
Reply 7 of 8, by mwdmeyer
Thanks guys. The cooling is really noisy on this card and I'm not sure why. So I'm not going to do any overclocking at this stage.
It runs like 50% fan usage all the time.
I have an X850 XT which I assumed would be way worse (due to higher clock speed and larger 130nm process) but it is actually much much better. The fan is normally running at 14% and is super quiet! It is a dual slot cooler so I suppose that helps.
I thought maybe thermal paste and I haven't replaced since 2005 but both GPUs run at 55-60c to very similar.
The cooler must just suck!
