Fried MB
First post, by Scott8bit
Well that was a short trip down memory lane, interrupted with the putrid smell of burning 🤣.
I’m not sure what has caused it as I did numerous tweaks but the motherboard died this morning.
I wondered what could cause it, as I’ve recently added overdrive + CD-ROM and powered CF card, so either too much voltage drawn could cause it? or the overdrive chip + system change to 66 MHz x2 could cause it? Perhaps just the age of AT PSU?
Annoying but now I have a ton of junk, so I’m going to have to source another socket 5 desktop and start again 🤣.
Anyone had similar issues with old hardware?
Reply 1 of 6, by Tiido
Sometimes transistors and other silcon shorts and dies like so. It looks like the switching transistor of some voltage regulator gave up. Assuming no other problems, replacing the transistor and the close by capacitor will make things work again.
Reply 2 of 6, by froller
Tiido wrote on 2021-02-27, 16:22:
Exploded power FET and melted inductor... smells like short-circuited low voltage power supply.
It had to be quite smoky.
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ 100%
Virus check complete. All viruses are working properly.
Reply 3 of 6, by Tiido
I missed that inductor completely, yeah, there's definitely a short down the line somewhere...
Reply 4 of 6, by Scott8bit
froller wrote on 2021-02-27, 16:33:
the house still stinks, Mrs isn’t happy she’s got all her Yankee candles on now haha.. I disconnected the PSU from the MB etc and it still seems to power up ok, I’ll have to check it with VOltmeter, wether or not I’ll risk using it again is another matter, I suppose it’s impossible to buy new AT Psus nowadays.
Thanks for the heads up on repairing, I’ll check into that, it’s probably easier to source the parts then find this exact socket5 mb
Reply 5 of 6, by froller
Scott8bit wrote on 2021-02-27, 16:18:
1. Check (with Ohm-meter) if melted inductor's rightmost (on photo) pin has direct connection to the ground. It should after all that damage.
Normally with all the stuff plugged into MB there should be at least hundreds of Ohms or more. I bet you'll read around 0.5- 2.5 Ohms.
2. Remove one by one every PCI device, memory and CPU checking if line is still shorted.
You either find who to blame or ensure you are screwed.
Reply 6 of 6, by cyclone3d
For a power supply, buy a nice, high quality ATX power supply and an ATX to AT adapter cable.
I refuse to use ancient AT power supplies when at all possible.
Newer power supplies output much cleaner power and have actual protection built in.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
