First post, by 386SX
I've got this Slot 1 mainboard supporting up to the Pentium III 600Mhz but the original cpu plastic mobile supports were broken. The parts fixed on the mainboard are ok but the above mobile part is now replaced with others that are not the right ones so the cpu seems to be fixed only by the connector.
I never understood if those things were generic or each mainboards had different solution to stop the Pentium II/III cpu into it. Do I have to try finding similar compatible ones or the specifics?
Thanks
