First post, by amijim
Hello Vogons ,back in the 2000s i published my saga in a win2000 installation quest and success story.I had published all needed information to othe 2cpu.com forum yet 20 later the information has been lost and various users are complaining about the Inacessible boot device BSOD .The solution is to install a SCSI autoboot card,preferable an adaptec 2940uw with a scsi hard disk and a scsi cdrom.All you have to do is to disable ps2 mouse and disable onboard ide interface because it messes with the IRQS and boot from a scsi cd rom.Then you can install as usual.I have just made a new era to the dual ppro win2k setup after having sold my Tyan s1668 over ebay last year.The new set up consists of a dual ppro 200 oc to 233 ,384 mv edi dimms ,riva tnt 1 Diamond voodoo2 8mb , AWE 64,Oricom ISA lan , Nec PCI usb 2,0 and Adaptec 2940UW.Photos will follow.The setup is robust and quite fast.Thank you Vogons for keeping the Retro Computing alive.Vive the 2cpu world!
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
