help upgrading cpu 486
Reply 20 of 26, by evasive
On the risk of getting burned: do you have a smaller sized CF card (32MB or something) that you can use for testing purposes? I want to make sure we are not running into a size limit of the bios before we start more troubleshooting.
Reply 21 of 26, by scroeffie
nope smallest i have is 256mb ,wil have to look on ebay but i dont think the limit is 32mb
my 386 big tower has a real hdd 205mb
if i buy a xtide card can i put in the correct values ,been looking ate youtube videos cant find info about this
Reply 24 of 26, by evasive
Well normally you would need to change settings in the bios and that is it. There is a small chance you can enable/disable the IDE controller with a jumper. For that We'll need to fabricate a layout with jumper names and locations, so we can compare it to known boards with the same or similar chipsets.
