First post, by Murugan
I got this baby AT 286 board in a lot I bought.
Can't find it on UH19 though. Closest one I got is this one but not exactly the same:
http://www.win3x.org/uh;19/motherboard/show/6752
Chipset is Headland HT12
There is activity on the board (my POST card shows 04 03 or vice versa) but I get no image.
I suppose I am missing the RAM chips 😀?
I like the spelling error on the Warranty sticker hehe.
Reply 1 of 13, by Deksor
Can you dump the BIOS ? We might be able to find the brand using the POST string.
Reply 3 of 13, by Deksor
if you have another 286 using the same kind of ROM you can probably get it to boot with the roms from this board 😀
Reply 6 of 13, by megatron-uk
Buy a set of 4 30pin SIMM sockets. You don't need to solder them on, but they'll push straight in to those SIPP sockets on the bottom of the board there, next to that last ISA slot. Don't bother with DIP DRAM, it will be limited to a maximum of 1MB with the HT12 chipset anyway, whereas with the SIPP/SIMM sockets you should be able to o use up to 4MB unless it's an absolutely brain dead HT12 bios implementation.
https://www.target-earth.net
Reply 8 of 13, by Deksor
Most 286 ROMs are swappable. The chipsets weren't specific enough yet to really prevent your computer from POSTing without the correct ROM.
Reply 9 of 13, by megatron-uk
There's a ton of Headland HT12 bios images, they all should work on each board - some have different options for speeding up the ISA clock, or enable zero wait states or the HT12 party trick of turning your extended memory into EMS.
Reply 10 of 13, by Murugan
The memory finally arrived and the board works.
Another one saved 😀
This is the BIOS string but haven't looked up who made it.
Note how 'Warranty' is written on both sides 😀
Reply 11 of 13, by Deksor
Apparently it's a "Protech Systems" board
To dump the BIOS you can use this program http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
Reply 12 of 13, by BitWrangler
What I've done with a board similar was to take SIMM sockets off a junked board and stuffed them in the SIPP sockets and installed SIMMs.... Or if you've got a box full of SIMMs you can solder them to single row IDC type headers.
Reply 13 of 13, by Murugan
Deksor wrote on 2021-05-15, 23:01:
Hmmmmm will need to see if I have spare IO card or borrow one from one of my systems since I tested this on a piece of cardboard with only VGA installed.
