First post, by Bancho
- Oldbie
Hi Guys,
I've put together a 486 PC based around a Asus VL/EISA-486SV1. The issue I'm seeing is after installing DOS, floppy disks refuse to read. I 'think' the drive is being recognised as a 360k/1.2m Drive. I get "Sector cannot be found" when trying to run things from a floppy.
I know the drive works as I was able to install DOS 6.22 for 3 floppy disks. If I boot from the 1st DOS floppy and exit to the command line, I can read floppy disk's fine. Its only when I boot into DOS from the hard disk, that's when the disks have this behaviour.
The floppy drive is running from a Winbond ISA Super I/O card. I have a EISA Tekram DC-620B as the HD controller. This also can host floppy drives too, but this has the same behaviour and I've disabled the floppy function on the Tekram to see if the Super I/O would behave any better, but it's the same.
Anyone experience this before? Can read floppy disks when booting from a DOS floppy, but won't read disks when booting from a HD?
