First post, by Remonter
Hello everyone!
I have old 5.25 FDD without markings. Manufactured in 1990. This FDD looks ok, but not working. I think this drive is DS/DD, because i have only HD diskettes and they not works with this drive. Or heads just need to be adjusted. At first i want to know what i have). The board very similar on Qumetrak 142 with shape and component placement.
1.23 MiB
1.71 MiB
424.4 KiB
745.54 KiB
Reply 1 of 7, by Miphee
Interesting burned mess at the power connector. Looks like a handmade conversion to replace a different (perhaps proprietary) connector.
Reply 6 of 7, by Remonter
I`ve checked disk rotation speed with oscilloscope. Drive has 300 rpm. Then i I have used Teledisk from Daves Old Computers site to test drive. Drive has 40 tracks. So, i know its DS DD drive. I saw some data on last tracks at 250 kbps. Now i am trying to find good DD 360 diskette to make head alignment with it.
What mean "RMS" jumper? When i removing this jumper heads move to center of disk.
Reply 7 of 7, by snufkin
Remonter wrote on 2021-05-18, 12:00:
I'd hazard a guess that it's the supply to the RM1 resistor pack, probably selects if the termination resistors are connected or not. So only fitted on the last drive in a chain. Bus signal levels might do odd things without it (like stepping the head to the middle). Maybe. I'm guessing most on the RMS->RM1 names being similar and the location. I think normally jumpers labelled MS would be to do with whether the motor started on the drive select or motor run signals.
