First post, by Woody72
- Newbie
Hi guys, Bit of a daft question probably bit I'd like to snag up a couple of spare PSUs whilst they're still around. I've tried searching for 'AT power supply' with mixed results but is there a better term I should be searching for? I'm referring to the PSUs with the side by side motherboard connectors and a physical switch. TIA.
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
