Reply 20 of 24, by luckybob
It was a late socket A thing. If memory serves. Pull the heatsink off a working P4 and equivalent amd, and the latter would usually save itself, where the p4 would start a fire.
Early socket A boards quite often had a thermistor inside the socket, but it really didn't make a big difference
Reply 22 of 24, by ultra_code
Doornkaat wrote on 2021-07-04, 09:42:
Guess AMD was a bit behind in tech.
Because they didn't include a thermal sensor in their CPUs?
Yep. 😀
Okay, for real, though: was space that limited that they couldn't put a thermal sensor in-die?
Builds
Reply 23 of 24, by bofh.fromhell
the_ultra_code wrote on 2021-07-04, 12:34:
Yep. 😀
I guess someone has to be the first one to do it.
And this time it was Intel with the coppermine P3 (?).
Tho it was very rudimentary IIRC, it just halted the CPU when temperatures were deemed to high.
Reply 24 of 24, by Oetker
luckybob wrote on 2021-07-04, 09:21:
I think it was the other way round.
