Reply 20 of 21, by maxtherabbit
- l33t
Jo22 wrote on 2021-06-08, 15:12:Edit: Couldn't the 1MB be configured for the 0-640KB range, too?
If the 286 chipset does have at least a little bit of intelligence,
it should be able to start with its first 640KBs of memory beyond 1MB.
no everything on the board is hardwired to where it is, that's why the "1MB card" would only provide 96kB
You're right about 8-bit for EMS on some add-on cards, if all OP wants is EMS then the 2MB lo-tech would be adequate, but the other cards I mentioned provide extra 16-bit XMS as well
