First post, by DeggMan
I purchased a 486 from someone awhile back, and tried to boot it up; nothing happened. I've had some free time lately, so I tore down the machine to the motherboard and want to boot it up outside of the case as simply as possible just to rule out what's happening. Having never built a 486 I'm confused by where case wires go, and what is needed to do a minimal hardware boot. I tried my hardest to identify the motherboard following some methods here (to find a manual) and this was the closest match I could find: https://th99.bl4ckb0x.de/m/U-Z/35297.htm. I should mention there was a power button on the case but it appears that there's actually no wires coming from it on the inside (you'll be able to see this in the attached photos). Thanks for all the help, all of this is alien to me! Was far too young to have ever had or touched a machine this old. Though I want to preserve it.
Here is an imgur gallery with all useful images of my hardware: https://imgur.com/a/UUAxIlV
Should mention I have all necessary cards for displaying video, they just aren't photographed.
Reply 2 of 19, by Ydee
Hi, You need connect the switch ON/OFF - 4 wires from PSU (black, white, brown and blue with Fastons). The colors of the wires on each contact are described on the label on the PSU, usually is black and white wire hot and neutral from the AC line in jack on the back of the power supply. Brown and blue should be hot and neutral on the AC out receptacle on the back of the power supply, but check it on the label.
Connect the board power supply so that the black wires of the two connectors are together in the middle. If the power supply is correct, when the switch is pressed, the board should be powered up and start starting. Try boot in minimal configuration, i.e. board+CPU+RAM+VGA and see, what happens.
    1.26 MiB
    887.91 KiB
    16.11 KiB
Reply 3 of 19, by evasive
http://www.win3x.org/uh19/motherboard/show/2602
https://www.ultimateretro.net/en/motherboards/2602
Reply 5 of 19, by megatron-uk
If you have never used an AT power supply before be very careful - there are two things to be wary of:
1. Mains level voltage (be that 100/110v or 220/230v wherever you are based) flows through that front panel switch - be damn sure you don't touch it or play around with it while the PSU is connected to the outlet. It's not like ATX where you have a low voltage 'power on' signal.
2. The two connections to the motherboard - P8 and P9 can be plugged in the opposite way around and it WILL destroy your motherboard. The mnemonic to remember is "Black to black is good. Red to red you're dead".
ATX solved these problems by using keyed connectors that could only be inserted one way and by using the low voltage power on signal to the front panel, rathe than mains voltage.
https://www.target-earth.net
Reply 6 of 19, by DeggMan
I've attached an image of how I have the wires hooked up to the power button. Let me know if those wires appear to be on the right way. Also, a better image of the power supply diagram.
Reply 7 of 19, by Ydee
Oh, the wiring scheme on the label is for power wires only. You have a more accurate schematic on the attached photo.
It's plugged in well - black is always under voltage if the power supply is plugged into a socket. By turning on the switch, the voltage passes through to the brown wire. Black and brown are working phases, so they have to be underneath each other. If the computer switches on at the OFF switch, flip the black and white down and the brown with the blue up.
    45.14 KiB
Reply 8 of 19, by DeggMan
Good news it boots. Here's this bios string I believe: 40-0400-006257-00101111-080893-U4800VLX-P. I'll have to get an adapter or appropriate keyboard before I can carry on further. It was American Megatrends bios of course.
Reply 9 of 19, by Horun
DeggMan wrote on 2021-06-06, 13:02:
Great ! The AMI bios string section 00101111-080893-U4800VLX matches this: http://www.win3x.org/uh19/motherboard/show/2602 as posted above by evasive
Reply 10 of 19, by evasive
Congrats on getting it to boot.
As for identification, OEM version, I don't have information on manufacturer ID 006257 right now. Will see if I can find more info.
In the mean time, if you can manage to make a backup of the bios (you can use this tool):
http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
And post that somewhere that would be very nice
Reply 11 of 19, by Kahenraz
megatron-uk wrote on 2021-06-05, 12:48:
This is somewhat terrifying; I didn't know this. I don't collect AT motherboards so I'm glad that I won't have to worry about killing myself as a result of being clumsy. At least not from the power on switch.
Reply 13 of 19, by DeggMan
evasive wrote on 2021-06-08, 16:06:
Congrats on getting it to boot. […]
Hey if you can help me find documentation on the motherboard again, I'll promise you the bios 😜
Reply 14 of 19, by rasz_pl
DeggMan wrote on 2022-08-01, 03:55:
Can someone help me find this motherboard online again, the site appears to have lost it's list.
evasive wrote on 2021-06-05, 12:31:
>Until recently, an archived version was available but someone has managed to deliberately remove it from archive.org.
I dont quite understand this statement. The only person able to remove website from archive.org is the current administrator for particular domain? and here is someone in full control of win3x.org complaining about "someone"
Reply 15 of 19, by Kahenraz
Archive.org has a policy where any subsequent domain hosts which contain a robots.txt that prohibits web crawling, all past historical archives will be unavailable, despite the absence of a robots.txt at the time of their archival.
I have had instances where things that were once accessible became inaccessible because a domain squatter bought it up once lapsed and had a robots.txt. I tried emailing archive.org for weeks but they never responded.
Reply 17 of 19, by debs3759
Looks very similar to https://www.ultimateretro.net/en/motherboards/2602
Does it not have a string anywhere on the board that might help identify it? I can't see all the detail on your photos.
Reply 18 of 19, by Horun
debs3759 wrote on 2022-08-01, 22:00:
That is same as the original link and yes that should be the board AFAIK.
Luckily the new UltimateRetro.net kept many of the same page # .
As far as the Archive Org removal of the archived page I have this to say: With "Sorry. This URL has been excluded from the Wayback Machine."
As a contributing member of Archive org and have dealt with other similiars can tell you either: someone at win3x.org OR the new site of ultimateretro.net informed Archive org that the data under /UH19/ was moved to a new domain and was their property. As Kahenraz mentioned it could be because of a Domain being bought but Win3x.org is still owned by same group so does not have much to do with a new added robots.txt that would effect an archive,
that only applies to new scans, not the old already archived ones. To be honest I suspect both parties culpable in this in one form or another....they split on bad terms. That is all I have to say about this ;p
Reply 19 of 19, by evasive
They did split on bad terms and all it would have taken was for the win3x.org owner to create a single redirect to the new location to avoid this mess. Nuff said.
