First post, by Socket3
- Oldbie
Hello everyone. I'm having an issue with a new 286 build - specifically I can't seem to get the mouse (serial mouse) to work under windows, although it works just fine under DOS.
Here is my setup:
Hardware:
- '89(ish) 286 mainboard with a 16MHz Harris CPU installed
- 4MB of RAM (4x 1MB 30 pin SIMM)
- Tseng ET3000AX ISA video card
- Creative Sound Blaster PRO 2.0 CT1600
- Generic ISA Multi I/O card using a Winbond chipset - a fair bit newer then the motherboard - made in 92 i think
- 800MB Western Digital IDE HDD
- 1.44 and 1.2MB FDD
- Sony 52x CD-ROM
- AT Power Supply, 200w (or so it claimes)
- Logitech M-M15 serial mouse - as well as 7 other Serial mice, different brands, working in either Logitech or Microsoft mode according to CuteMouse.
Software:
- MS-DOS 6.22
- Windows 3.1
- CuteMouse driver or Mouse.com microsoft driver that came on a Mistsumi driver FDD.
The mouse works great under dos - mouse is detected normally, and functions as it should. Both cutemouse and mouse.com detect the mouse correctly. But as soon as I run windows 3.1, the cursor won't move. So far I've tried:
- using other good, working serial mice - all exhibit the same behavior - ok in dos, no-go in win3.1
- replacing the Winbond I/O card with others - so far I tried a much older one with a Fastrack? (not sure) chipset and one with a Godlstar chipset. With the older I/o card, only some mice work under DOS - notably those that run in Logitech mode. With the Goldstar card I get the exact same behaviour as with the Winbond card - ok in dos, won't work in windows
- went trough all mouse drivers supplied with windows 3.1 in control panel -> windows setup
- attempted to install an old Logitech win 3.11 driver off a floppy that came with a logitech mouse - and failed.
- removed the CT1600
- switched from COM1 to COM2
- loaded a mouse driver under dos, then loaded windows
- ran windows without running a mouse driver in dos
So far, nothing has worked under windows, and it's driving me up a wall. I had similar issues with a 486 ISA build a while ago and could not resolve them. That time it was running Windows 3.11 for workgroups.
Can anyone help?
