Reply 20 of 26, by zapbuzz
- Oldbie
Where the bus speeds are low the bandwidth is narrow but a RAID can seek quicker.
VLB is just PCI in reverse they realised its true potentul is why it became PCI instead (and to satisfy the critics saying VLB wasn't true 32bit.)
I had VLB graphics card CIRRUS LOGIC and 4 IDEport card back in 2006 it supplied true colour and good data seeking performance I would love to see a vlb and PCI motherboard but there isn't
I think its because VLB could be called the first 32 bit bus and PCI was the winning design.
Perhaps there was a VLB RAID solution but where the disks are these days would be hens teeth and even smallish flash drives that could run together with adapters for IDE.
SATA would be double the front side bus speed needed to run so the old motherboard wouldn't be able to function without freezing the graphics stuttering the sound and generally beng completely challenged.
