First post, by UltimateElectronic
G'day all, has anyone else had a problem where essentially none of the front panel connectors on an M571 haven't worked? All of the ones I've tested haven't worked, which are the HDD LED and the ATX power switch with an ATX PSU.
Thanks in advance!
UltimateElectronicFun
