First post, by britain4
So I’ve picked up a nice little baby AT machine recently for another “build” - it’s all up and running as is but with onboard everything so the plan was to just throw a Voodoo1 in it and a sound card, and call it a day.
There’s been a fail with the board layout of the PCChips M598LMR though - clearly not designed for any large PCI cards the CPU socket is directly adjacent to both of the PCI slots and the Voodoo card is about an inch too long to clear the heatsink.
pc-chips-m598lmr-socket-7-motherboard-sis-530-chipset-with-isa-system-board-1.1297__45867.1489936678.jpg
I feel like I’m just going to have to swap it for a different board but I’m reluctant as it has all of its extension brackets and stuff. Anyone run into this issue before and used a PCI riser/modified the heat sink etc to get around it?
Edit: having looked at it a bit more I think I can just Dremel just the lower left corner of the heatsink fins off and make room for it that way?
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
Reply 1 of 15, by megatron-uk
That board definitely gets a "Fail" for layout! A mix of expansion slots and IO headers where only expansion slots should go?
https://www.target-earth.net
Reply 2 of 15, by zyga64
You may try riser like this
...but probably not in the standard AT case. BTW. Onboard soundcard is not that bad (it is rebranded CMI8330).
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 3 of 15, by britain4
megatron-uk wrote on 2021-07-09, 08:49:
The layout is awful - completely defies logic, it would have been a cheap board in its day but if the CPU socket was just half an inch higher for example you could use any PCI card you wanted in the bottom slot 🤦🏻‍♂️
zyga64 wrote on 2021-07-09, 09:26:
I didn’t think so about the riser - nowhere at all to mount it.
Good to know about the onboard sound, thats a silver lining at least as I can see potential issues with longer sound cards and the front panel headers
I went ahead and just cut some fins off a heatsink - thankfully it all now (just) fits fine with not much material lost from the cooler. What a tight squeeze but nothing can catch on anything else so I think it’ll be fine.
Reply 5 of 15, by britain4
pan069 wrote on 2021-07-09, 10:30:
It happens to AGP boards as well 😀
PCPartner Socket 7 epic design fail
It does make you wonder what they were thinking when boards with perfectly fine layouts had been manufactured before… 😂
Reply 6 of 15, by cyclone3d
The ASUS P5A-B also has a bad layout. Almost any AGP card has issues clearing the CPU heatsink. Electrical tape to make the AGP card not short out on the heatsink is about the only thing you can do.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 15, by BitWrangler
The other way to go might be to look for tail end of socket A heatpipe sinks that are tall enough that cards fit between the pipes.
Reply 8 of 15, by cyclone3d
That's a bad idea. Let's sandwich a card in between two towers of heat.
YMF7x4 Guide
Reply 9 of 15, by britain4
BitWrangler wrote on 2021-07-09, 16:17:
Not a bad idea - I’ll keep my eyes peeled for one. For now I think the cut down heatsink works well enough. Top slot is still restricted and I don’t have anything that fits so it’s onboard video + Voodoo for now.
Hopefully a K6 or a Pentium or a Winchip or whatever I decide to go with won’t be putting out enough heat to affect the graphics card too much?
Reply 11 of 15, by Miphee
Not a big deal now.
    197.99 KiB
Reply 12 of 15, by PcBytes
I think most AT Socket 7 mobos had bad clearing issues and ATX ones didn't. Feel free to prove me wrong though.
Reply 13 of 15, by Horun
cyclone3d wrote on 2021-07-09, 15:36:
Agree ! Do not want to short the back of video card.
Reply 14 of 15, by Schule04
PcBytes wrote on 2021-07-09, 20:07:
And many Socket 5 boards had the CPU placed behind the ISA slots, blocking long cards.
Reply 15 of 15, by Tiido
Yeah, I see this problem with most Pentium and newer AT boards, 486 and 386 boards not that often.
