First post, by kane198021
Hello all,
It's been a while since I last posted. I'm ISO the specific part in the title of this thread. If anyone has one to spare or at least can reverse engineer it, please post a reply here.
This part is a 386 CPU card for certain AST PCs. It came with a 20MHz or a 25MHz CPU soldered directly to the PCB, depending on how the machine was spec'ed. I have the 202382-005 motherboard on hand, but it needs some love, much like any of the machines we talk about here.
I came here with the hopes that I could get something to get this board resurrected. I have been searching for a card for over a year now and I have a saved search on Ebay. I'm not sure what else I can do.
Thanks in advance!
Reply 1 of 2, by BitWrangler
I thought maybe I'd seen one sometime, but looking it up it appears to look like a card with an edge connector correct? The one I saw was one that mounted flat on similar plugs to IDE cables, probably for an Advantage, not a Bravo.
Reply 2 of 2, by kane198021
BitWrangler wrote on 2021-08-11, 03:30:
The edge connector looks very similar to an IBM MDA slot or a PCI slot except shorter.
