First post, by pixelatedscraps
- Member
Looking to SCSIfy my ultimate late ‘97-early ‘98 build and dual boot Windows 98 and NT 4.0. What would be the top-end, period correct hard drive boasting maximum capacity (dual boot in mind) and performance up until mid-1998 to go with either an onboard Adaptec AHA7880 or a 2940U2W add in card. Bonus points for ultimate CD drive as well, obviously.
My build features dual 333Mhz Deschutes cores on an Asus P2L97-DS, hence the dual boot to utilise the second CPU.
How big is too big? I remember there being a FAT16 size limitation on initial Windows 98 releases but am I able to partition a larger drive, say a 146GB, and install NT4 later on the remaining space or will that only work if I step outside period correctness (eugh) and install Windows 98 SE first?
And had 15k drives appeared yet?
This is definitely beyond my knowledge and interweb sleuthing abilities.
Thanks all. This build is inching closer and closer.
