Reply 20 of 24, by snufkin
Datadrainer wrote on 2021-09-14, 12:33:@HanJammer. Yep Would means VRC, but for me, except one is embedded, it's the same. But yes, for latter 486 till Pentium Pro, plugable voltage regulation modules was great.
I'm asking myself a question for a long time now. Could it be done to use tulip socket to insert caps? Or is something wrong with that. That question came following a thought about having a way to easily replace all components prone to fail on old hardware. I got capacitor who inflate to the point they broke the trace where they where soldered. With socket they can just pop out and they are easier to check.
Couple of reasons I can think of. One would be cost to the manufacturer for the parts, and possible reliability issues if capacitors fall out during shipping. The other is that you want the leg length to be as short as possible to reduce the inductance in the path from the power supply to ground. Also, the extra height could be a problem if they then clash with heatsinks/fans. So the benefit of time saved by having the socketed probably isn't worth the downsides. Generally they last pretty well, apart from the early-mid 2000s when someone managed to steal a bad formula for the electrolyte used in the capacitors: https://en.wikipedia.org/wiki/Capacitor_plague
