Reply 20 of 20, by Pabloz
7ZX is a nice board with the blue pcb
sadly during that era they released many revisions and if you had revision 1.0 or 1.01 then you would be stuck with support up to an athlon xp 1800 i belive.
while if you had revision 5 you would end up havind support up to athlon xp 2400 or 2600.
that kind of sucked, the same thing happened with a SOYO board that depending on the revision you had more cpu support.
the board is also good for its universal agp, you could put a voodoo card for example.
