First post, by jheronimus
- Oldbie
Hi, all
I recently got myself an OEM version of Pentium II Overdrive that only comes with a heatsink. I think it's intended for servers that probably have some built-in case fans, but I'm still wondering whether I need to add some kind of active cooling.
Maybe someone has experience with a chip like that and has found a good solution? I got mine for a lower than average price, but still kind of expensive, so I wouldn't want to damage it. I've used it for about 20 minutes and I think the heatsink got to around 50 degrees C (I only have a food thermometer, so not too precise) and the part of the motherboard behind the socket got pretty warm as well.
Then again, I think a lot of systems used late Pentium 2 and Pentium 3 chips without fans, so maybe I shouldn't worry?
