First post, by joed96
Hello,
I'm hoping to seek some advice from some power supply experts. Super short story is that I'm seeing 13V on my 12V line with 2 brand new AT power supplies, and the voltage increases under load. Slightly longer story...
I'm building out a retro PC with an ASUS P5A-B, K6-2 500Mhz, S3 Trio64V+, NIC, USB card, and a pair of SSDs connected through SATA to IDE adapters. The case arrived with a power supply, but as I've never really dug into power supplies and don't feel comfortable checking the capacitors etc on an older power supply, I immediately replaced it with a brand new Athena 400W AT power supply. I've been using the system off-and-on for about a month without any issues, but haven't fully built it out as I'm waiting for a couple final parts.
I tried to replace that video card with a Voodoo 3 3000 AGP card. When powering up the system, the BIOS displayed an error that the 12V input is high, at around 13-13.1V. I actually have two of the new Athena power supplies, so tried the other one and again observed 13-13.1V.
So taking a step back, with the power supply on it's own (no load, just input power and a digital multimeter), I'm getting the following voltages:
* 12V = 12.68V
* 5V = 5.31V
* -5V = -5.00V
* -12V = -12.06V
I couldn't be happier with the -12V and -5V lines, but the 12V and 5V lines are just above the +/- 5% thresholds. I am aware from other threads that testing with no load isn't particularly useful and also that the voltage may come down with load applied. So, I thought to put the system back together and test with a full system. This is where I'm getting a bit confused...
With the system put back together and using the S3 Trio64V+, the 12V line voltage increased to 12.99V. When I swapped out the video card for the Voodoo 3, the voltage increased further to 13.09V. This is tested with a digital multimeter, not looking at BIOS values. I didn't go past the BIOS while running this test, so again the load on the power supply wouldn't be high.
Given that I've used two brand new power supplies, it seems less likely that there is a power supply issue (although I can't rule out a bad batch). Perhaps I need to fully boot the system up and get some more load on it to see if the voltage levels out to a good place. However, I'm worried about whether the high voltage would cause any problems to my components if I run the system long enough to test this.
That's where I've gotten to, and would certainly appreciate any guidance or knowledge anyone might be able to offer.
Cheers!
Reply 1 of 18, by cyclone3d
Yep, bad design or faulty.
I personally don't trust any power supplies except ones from very reputable companies like Seasonic.
For AT systems, I use an ATX to AT adapter.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 18, by waterbeesje
Could you provide more details of the PSU? Type name and some amps it should be able to provide per power rail?
Some rebrands use the builders type name (like a HP or Dell branded pus with FSP type name)
Maybe you could open one up and take a picture from the inside? That way we can help telling you whether it's a quantity PSU.
Of course you must be sure you'll want that, as opening it up will probably void any kind of warranty (if you have that).
Or if you can look inside thru the holes, you might see if all party's are mounted on the PCB (and none let away) and if the great sinks seem to be decent sized. That's a pretty ok way to see if it's probably ok quality.
It's a known easy way to cheap out a PSU by shrinking cooling sinks and to let away party's that are then bypassed by a little wire.
If all party's are there and seems decent, that's where my knowledge ends.
Stuck at 10MHz...
Reply 3 of 18, by TheMobRules
I don't think those Athena AT units are very good, at least from what I've heard, so pictures of the inside would definitely help. The Startech ones, on the other hand are quite reliable... the protection on those saved me from an incorrectly plugged P8/P9 connector the other day.
Another reason may be that the PSU requires a minimum +12V load to regulate properly, can you try adding a mechanical HDD to the mix and checking if that improves the voltages?
Reply 4 of 18, by retardware
waterbeesje wrote on 2021-09-21, 18:37:
I loved that 👍
TheMobRules wrote on 2021-09-21, 19:04:
Yes, it is that dreaded crossloading problem.
When one rail (here +5V) is loaded too heavily in relation to the +12V, the latter goes up.
Either replace with a good AT PSU (preferably Seasonic), a modern PSU that creates +5V etc from the main rail (e.g. 12V) using DC-DC converters or add dummy loads (HDD, resistors, loads of LEDs with resistors or whatever) until voltages stay in range.
If you add a HDD, make sure you take one which isn't too energy saving, e.g. a 3.5" or even 5.25", which draws at least 0.6-0.8A, the more, the better 😀
Reply 5 of 18, by joed96
cyclone3d wrote on 2021-09-21, 17:44:
Hi, thanks for the response! That would be a great solution and I would feel more comfortable running a modern, quality power supply - especially from a brand like Seasonic.
I initially steered away from this as I was worried about the lack of -5V on modern power supplies. But, maybe I'm unnecessarily worried about that. I think I now understand that only the ISA bus potentially used -5V, and the only ISA card I'm looking at is either an SB16 or AWE64 which I believe don't use the -5V power. Does that sound right?
Am I therefore ok to just run without -5V and just need to ensure that the ATX power supply has a strong enough 5V rail? Any other specs I should look for in the power supply?
Thanks again!
Reply 6 of 18, by joed96
Hi, thank you and retardware for the response!
I’ve added a Seagate Barracuda which draws +5V@0.85A and +12V@0.75A and the voltage on the 12V rail reduced from 12.99V to 12.91V. Not a huge change, but it sounds like confirms the cross-loading design issue?
Photos and details on the power supply forthcoming once I get it out of the system.
Reply 7 of 18, by joed96
Could you provide more details of the PSU? Type name and some amps it should be able to provide per power rail? Some rebrands us […]
Hi, thank you for the response!
The power supply is an Athena Power AT40 400W power supply. The rails provide:
+12V@18A
+5V@32A
-5V@0.5A
-12V@0.5A
I'm attaching photos of the unit. I really have no idea what I'm looking at, but would be interested in comments on the quality of the build.
Thanks again!
    257.8 KiB
    Athena AT40 Specs
    229.91 KiB
    Athena AT40 Left Side View
    253.97 KiB
    Athena AT40 Right Side View
    251.55 KiB
    Athena AT40 Top Down View
Reply 8 of 18, by retardware
Ugh that looks like FSP :vomit:
No filter and fan of the cheapest sort.
That is not what I like or even would consider using myself.
Asides of that, just the current draw of the inactive HDD of maybe 1/3 to 1/2A on 12V probably doesn't constitute a sufficient load for this PSU.
You need something heavier.
Or just a good PSU.
Reply 10 of 18, by joed96
retardware wrote on 2021-09-22, 01:11:
Ugh that looks like FSP :vomit: No filter and fan of the cheapest sort. That is not what I like or even would consider using my […]
Or just a good PSU.
That good huh? Sigh, I really wanted to like these as I was so happy to see someone manufacturing new AT power supplies.
Just as a bit of a tangent, I thought FSP was generally well regarded. Did I get that wrong, or does it vary between models?
I'll see what I can find in terms of a good Seasonic power supply with a strong 5V rail and an ATX to AT adapter.
Thanks again!
Reply 11 of 18, by joed96
cyclone3d wrote on 2021-09-22, 01:14:
Yeah.. I wouldn't be using that PSU.
Thanks! I'm disappointed about the PSU, but happy to be steered away from it now rather than end up in tears down the road.
Reply 12 of 18, by retardware
joed96 wrote on 2021-09-22, 01:26:
My personal impression is that FSP is best regarded by people who did not do test bench examinations.
I originally considered FSP an acceptable brand until I did my tests. What I found made me dislike FSP very much. Bad design, dangerous construction (on some of their PSUs one can touch live with the fingernail) and other questionable things,
Reply 13 of 18, by joed96
retardware wrote on 2021-09-22, 03:07:
Thanks for sharing, very insightful! It certainly helps to be more aware.
Reply 14 of 18, by canthearu
joed96 wrote on 2021-09-22, 00:58:
Hi, thank you for the response! […]
+12V@18A
+5V@32A
-5V@0.5A
-12V@0.5A
Thanks again!
The secondary side of that PSU is brutally undersized (side opposite of the large primary caps) Should be a LOT more capacitance on that secondary side, at least for this particular design at this particular wattage.
I'm not going to turn around and say the design if particularly bad ... I see this design a lot and a lot of computers operate fine on PSUs of this design. But this particular example is no good.
And if the group regulation hasn't been tuned properly for 5V heavy applications, you get what you are seeing with the 12V shooting up as the PSU inadvertently adds more energy to the 12V circuit at the same time to delivering more energy to keep the 5V rail propped up.
Reply 15 of 18, by TheMobRules
First of all, that PSU is not FSP at all. While FSP is not a top tier manufacturer, their designs are at the very least decent and their units are packed with components and quite heavy, that one is full of air.
Also, that power supply is just a regular bad quality ATX repurposed as AT, you can even see the empty spots for the 3.3V output components and rectifier.
Finally, old 5V based hardware is much more tolerant of ripple than newer low voltage components, that's why so much stuff from the 90's still survives to this day despite being run with power supplies that would be considered inadequate today. In fact, even the earlier ATX specs allowed up to 120mV of ripple on the +12V line, which was later reduced to 60mV. So just get something from a known manufacturer that is in spec and call it a day, no need to overthink it.
    atxps09_atx_pc_pow_supply.pdf
    112.89 KiB
    34 downloads
    Intel ATX Power Supply Design Guide
Reply 16 of 18, by joed96
canthearu wrote on 2021-09-22, 05:10:
TheMobRules wrote on 2021-09-22, 05:15:
Thanks you both canthearu and TheMobRules. That definitely helps me understand why my voltage was going up and that I clearly want to stay away from that power supply. And you were right, I was massively overthinking the -5V rail that I don't even need.
I went down to the market and got a Seasonic Focus GX-1000 - overkill over all, but it gives me 25A on the 5V rail and fits in my case. I'm getting 5.066V and 12.10V with this power supply, and I'm much more confident in my setup.
Thanks again everyone!
Reply 18 of 18, by retardware
To me it looks like a custom-cut-down FSP PSU.
The middle cooler that touches the case is characteristic for the FSP design. On some models, it is attached to the case with a screw, on others it is insulated from the case using a thin piece of soft thermo foil that one can pierce with the fingernail.
Another characteristics is the mains electrolytics which are surrounded by hot stuff in a sparsely-vented part of the board.
However, I didn't spot some other typical FSP "goodies" like electrolytics wrapped in shrink tubing to "insulate"/"protect" them from nearby hot transformers and coolers.
These have probably cut down like the filters for cost-saving.
Not so sure about this. The early DC-DC regulators had to work much harder when +5V was down substantially.
I have a 1999 AT form factor Tualatin board with bulged electrolytics and replaced CPU mosfets from Russia, and I would be so curious about the PSU it was being operated on before that PC was being dismantled for parts.
Yes I agree with you, especially as the modern trend is to derive +5 and +3.3V from 12V via separate/additional DC-DC converters. This makes the annoying crossloading problem nonexistent.
