First post, by Einherje
I recently acquired a four speed SCSI CD-ROM drive (IBM 88G4919) for my Pentium MMX build. I'm very happy with it, but I would like to hook it up to my SB16 (CT2230) and I don't recognize the audio connector:
Although the connector has 4 pins as expected, the two different types of jacks I have on my audio cable doesn't fit:
I've been fooling around on eBay for a while and can't seem to find a jack that looks like it would fit this type of connector.
Can any of you help me find a source for a suitable cable?
Reply 1 of 3, by Errius
Yeah that's the proprietary Panasonic connector.
Re: [SOLVED] CD Audio cable question
Search U.S. eBay. I bought two of the cables from a guy over there.
Protagonist: Robot
Reply 2 of 3, by Einherje
Errius wrote on 2021-10-01, 08:39:
OMG thanks! Panasonic was the keyword.
Thanks, thanks, thanks!
Reply 3 of 3, by Errius
Take care that there appears to be a 3-pin "Panasonic" connector as well but your drive uses a 4-pin connector. I've never seen a drive that uses this 3-pin connector. Ask the seller to clarify this before buying.
Protagonist: Robot
