First post, by stealthjoe
I found a Gigabyte GA-6ZXC rev 2.0 board with one seller locally which I am interested in procuring (apart from a GA-6BXC rev 1.9 found online). Have a few queries regarding this board before I make the plunge. Understanding is that this board (ZX chipset) is a stripped down version of BX chipset which can support only max of 256MB RAM. Also the manual states that the CPU support is only from 333Mhz P2/Celeron onwards (as compared to 233MHz P2 for the BX chipset). As this is a 2.0 revision, there are 2 jumpers for Voodoo 3 support. My questions are as follows:
1) Would the BX chipset of the same manufacturer (GA-6BXC rev 1.9) be better than this ZX chipset (which has rev 2.0) or otherwise?
2) Could this ZX chipset support processors less than 333 Mhz P2?
3) I have read somewhere that rev 1.9 boards don't have proper Voodoo 3 support. Is there any truth to this?
Please help me to choose between GA6BXC (rev 1.9) or GA6ZXC (rev 2.0).Appreciate your replies. Thank you!!
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98/XP
