First post, by candle_86
- l33t
So I got a Batman's revenge with a Pentium 66. The original heatsink retention frame was with the board but the heat sink was not so I managed to adapt a small aluminum one with some zip ties on it'll be a picture you'll see it. The question is after looking at the picture do I need to actively cool it meaning purchase like a 30 mm fan or should it be fine the way it is.
