First post, by moog
Hi everyone. I've experienced this issue on 2 motherboards already - Epox D3VA and Abit VP6. After installation is finished, the IDE CD drive, no matter how old or new, is recognized as a 5.25" floppy drive. I've managed to fix this on the Abit VP6 by updating the IDE controller's drivers, but the Epox' drivers seem largely lost to time.
Any clue what could be causing this? FWIW FreeDOS 1.2 and Linux 5.10 recognize the CD drive correctly. Not sure about XP SP3, I'm about to find out.
Audigy 2 ZS in FreeDOS
LinLin adapter documentation
+ various capacitor list threads
Reply 1 of 2, by Horun
This 2001 archive lists the drivers suggested at Epox at that time including drivers for Win9x.
http://web.archive.org/web/20010621203954/htt … oad_ep-d3va.htm
Looks like you should be able to use any VIA 4-in-1 up to v 4.43 for the Apollo Pro 133A chipset and WIn98 according to a vogons post VIA 4-in-1 driver experiences
Phils has v 4.35: https://www.philscomputerlab.com/via-chipset-drivers.html
Vogons drivers has a few: http://www.vogonsdrivers.com/index.php?catid=32
The Raid driver is trickier because the driver version should match the Highpoint BIOS version...
you can try this one: https://www.driverguide.com/driver/detail.php?driverid=49733
That is all I know and am probably wrong....
Reply 2 of 2, by moog
The root cause turned out was resource congestion. I didn't mention this, but during installation, the computer had ACPI enabled, IRQ3 reserved for Wake-on-Modem and all PCI/AGP/ISA slots were occupied.
I have removed almost all devices except for the ISA soundcard and AGP video card, disabled ACPI, disabled WOM and attempted to install Windows 98 again. This time around I still get the mysterious 5.25" drive out of nowhere, but at least now the IDE controller does not encounter any resource congestions and Windows 98 is able to work it correctly and detect the CD drive.
Nevertheless, thank you so much for the links! They will certainly prove very useful along the way.
Interestingly enough, I have tried to use HPT370 driver for Abit VP6 on the Epox D3VA. It doesn't make any problems yet.
